Sony PCV RX403N
Sony PCV RX403N
Hiya,
How do I make my DVD Player on my PC Multi-Region?
I use Power DVD.
Rick.
11 REPLIES 11
kee-lo_
You could try:
- DVDGenie
- DVD Region Free
See which one works for you.
are they proggys and where do I get them from?
robpaxton
You will have to use DVD region free from www.dvdidle.com
Because your drive has RPC2 firmware DVD genie will not work.
Regards, Rob
Regards, Rob
Thanx Rob - I have tried the software - you get an evaluation period of 30 days before you have to purchase a release code which costs aoround £30.
Not bad really - as a decent region 1 DVD player costs anything from £70 upwards.
Thanx.
Rick.
robpaxton
Have you tried the Pro version - the one that caches the data from your drive?
If you have, does it reduce drive access as much as the site claims?
Regards, Rob
Regards, Rob
Rob,
I am new to DVD's on PC's - I don't understand what you mean by caching etc!!
Sorry!
Rick.
robpaxton
Caching just means that it reads a big chunk of data from the DVD to memory and then uses the data in memory to play the DVD.
It should save battery power (on a notebook) and reduce the time your dvd drive has to run to play a DVD thereby reducing wear and tear on the drive.
Probably not a huge problem for your desktop machine however :slight_smile:
Regards, Rob
Regards, Rob
Rob,
There is a slight delay intransfer - not as smooth as my regular dvd player in the lounge - but this saves me from having to chip my Sony DVD player which I have been quoted around £80 to do so.
Rick.
robpaxton
Thank you for your reply - The sooner DVD region coding goes the way of the Dodo the better.
Regards, Rob
