RS324E problems, maybe general problems, please help!
redshark
I got a PCV-RS324E in January 2004. I had many problems to start off with but wont go into too much detail now unless you think it might be necessary. Basically, my PC didnt work at all for the first two months of owning it. so was sent back twice and out of the three months before it was "fixed" I could use it for about 8 days!!
Anyway, my version of Photoshop elements seems to have stopped working completely so I tried to reinstall it from the reboot CD but when I try to install individual programmes it says that the CD cannot be read by my PC, I can however reinstall all the software but I dont want to do that. Any ideas?
Secondly, I have come across one or two programmes (Picture Studio) that when I try to do anything with it it says that it only works with RS series computers, hmmmmmm, I have an "RS"324E, I mean what the heck is going on?
Any help or info would be greatly appreciated.
5 REPLIES 5
reaper
try and reinstall them using the recovery disk you said that you didnt want to installed all of them
it will only install the ones that arnt on your pc and will just install over the ones that are,
if you look in your user manual it reccomends you install all applications if you arnt sure which are installed it will cause no harm
as you dont want them all installed you can just uninstall them when installed,
i cant help with the programmes not working it sounds like you purchased a retard vaio lol complain, keep complaining until its sorted
kind regards ben
redshark
thanks for that, I think this Vaio has been doomed since I got it :S
Thing is I dont want to install over the programmes I already have on there, for example SonicStage, I have all my music stored there and dont want to have to reinstall it all. I still think that the CD should let me install individual programmes, especially if it gives me the option!
What have Sony done to me?
kee-lo_
Make sure you back up SonicStage and backup the database before you make any changes.
redshark
oh well, I phoned Vaio link, AGAIN!!! and guess what? they are taking it off me AGAIN!!! :cry:
I asked about the questions I asked here and also let them know that there is nothing in my Vaio System Information and I think that tipped the balance.
So thats another 2 weeks without it, I just hope they give me a replacement this time, it is normal that if it has to go in three times you get a new one? right? or is it just Urban Myth?
I love Sony products so much and now they have really let a regular customer down, I just hope nothing ever goes wrong with your Vaios.
:cry:
kee-lo_
I should really hope they will change your VAIO for a new one, but the bad news is you'd have to reencode all your music again :cry:
