Hi
Ever since I bought my laptop I have had several problems with the pre installed software installed on my FE31H laptop, main problems being:
1) when closing roxio digitalmedia, i get the following errors
*Mediahub.exe. the instruction at "0x0036ae50" referenced memory at "0x0025f5d0" the memory could not be "written"
*Mediahub.exe. the instruction at "0x12985383" referenced memory at "0x00000000" the memory could not be "read"
*RUNTIME ERROR R6025 pure virtual function call
these happen everytime I close the roxio program, I have tried reformatting my vaio and still get same errors
2) How do I receive my upgrade to Adobe Premiere elements Pro and Photoshop CS as stated on the "VAIO promotions" and "Upgrade your software" under the start program-All programs list. as the link in the advert doesnt work.
I have been trying for number of months now and thought I'd try this forum, as I have all these pre installed programs on my laptop and either cannot get rid of them or cannot use them.
Anyone who can help I would be so thankful as I am not that good at resolving error messages.
Hi Thanks for the reply, I will try your suggestion now, thanks again
Does anyone know anything about the Adobe software upgrade? can they recommend is it worth keeping or shall I just uninstall it? as the version on the FE31H seems quite old now compared to the versions on the website,
Tez
