I want to use my internal mouse rather than an external. Via the Control Panel/Mouse/Buttons I have been able to do all I need except to make the right button be a right click. If I chose click from the scroll down menu, it is the same click as the left button.
There is probably a simple trick to fix it, but I cannot find it.
Help is very much appreciated.
Hi artistemma,
The default settings for a right handed mouse are as follows,
Left button - Click
Right Button - Shortcut menu
Both Buttons - Auto Scroll
Hope this helps.
Thanks a lot Thalamus!
I didn't not link s"hortcut menu" to the "right click", but now I understand better and it is working fine!
You're welcome artistemma, glad your mouse is better again now. :smileygrin:
