Hi All, Can anyone help. I have an RX514 and when it appears to be stressed ( DVD & HDD running etc ) it sometimes starts flashing a red led in the same switch as the normal blue led. It also makes a load beeping sound. At first I thought it was linked to USB overloads as I had messages about power surge on USB ports , but I have installed a powered HUB and it still occurs. Cant find anything in the user manual , can you guys help. Many thanks
hi
i have to say your problem sounds a little strange the light flashing red
i have heard of the blue light flashing on anf off before and was sorted by cleaning out the dust from inside there vaio
you should clean your pc out see if it helps it in anyway it had something to do with the set up inside the power is to close to something
kind regards ben
"SONY NEED A SEARCH ENGINE !!!"
