Dear All,
I have sony vaio PCG-FR315M laptop. It has very loud noise and dont know what to do about it. please help.
thanks in advance
Hi and welcome to the forum.
How old is the notebook? If this has developed recently it may be that the cooling vents need a clean.
I suggest that you download MobileMeter and check the CPU temperature.
Rich912,
The English hyperlink does not seem to work on the mobilemter page, so I have posted an alternative link
Hope you don't mind
Thanks for that Thalamus, no it is not working at this end either.:smileyconfused:
You can of course just click the download link in the Japanese page but your link is certainly clearer. Thanks:smileyhappy:
Dear All,
Thanks a lot for the quick replies. I thought about the cleaning thing and tried to open the laptop, but did not manage to even after removing all screws. Is there any hint for unassembling it?
I searched on the net for a long time and found instrutions for many models but not for the PCG-FR315M model.
Also, is there a fan driver from sony, or an upgrade for the BIOS that can help?
i just downloaded the mobilemeter and found that the temperature of the CPU is 51.
thanks a lot
This is a guide for the FR215H, as posted by another member, but your model will be very similar. Click on the English link at the top of the page.
Dear All,
thanks a lot
51 is quite high for a notebook in my opinion. Mine is at least 10° less. Be glad your fan still works properly (though load), otherwise you might experience other problems.
Mine seems to runs smoothly & happily at 48 to 51
I get the same sort of temps as Rich
