PCV-RX1 Need to remove both side and front panels
JohnPowles
I want to replace my CD-RW drive with a Panasonic DVD-RAM drive.
It seems that I need to remove both side panels and the front panels.
I have the left side and top off and can access the cage for the drives but I cant work out how to remove the right side.
Any advice please?
2 REPLIES 2
iainjturner
The right hand side seems perminantly attached to the chassis on my model. You should be able to unscrew the drive cage and take it out...
Stephanius
correct Iain.
