No memory stick drive icon / TX2
Moak
after installing new windows XP and all the Vaio drivers, the Windows Explorer shows no icon for the drive "Memory Stick (E:)". Instead it shows a broken icon now... I tried to reinstall (latest) drivers but this didn't help. Thanks for help.
I have had a German Windows before, today installed an English version of XP pro and all the latest drivers. All seams to work fine, just the missing icon in the Windows Explorer is ugly. :slight_smile:
/Mark
4 REPLIES 4
Thalamus.
Champion
Hi Moak,
Welcome to Club Vaio, :slight_smile:
Rich912 posted a solution in this thread
Hope it helps..
Moak
Thanks, works!
Thalamus.
Champion
:cool: You're welcome..:smileyhappy:
Oguzhan
moak i had a same problem i solved if you want help send me mail [email protected] i will send you dll file and you will solve this problem
