My sound keeps distorting
Love4MusicUK
I've only had my laptop about 3 month and now my sound had started to distort. Can anyone help? I hope it's not a hardware problem...Had to format the other week because a virus had messed up my computer files, about a week after is when it started to distort the sound when watching videos, playing music etc.
9 REPLIES 9
rich912
Contributor
Hi Love4MusicUK,
A few things that you can try...
1 Check that there are no enhancements enabled. Right click the speaker icon in the system tray and select Sounds > on the playback tab select Speaker/HP and then click properties > on the enhancements tab check ‘Disable all sound effects’ and then apply.
2 Check Vaio Support for updated audio drivers.
3 Uninstall the device in Device Manager and then reboot and reinstall drivers.
4 If by any chance you have installed any third party audio software since the recovery then try uninstalling .
Go n-éirí an bóthar leat
Love4MusicUK
Hi Love4MusicUK,
I've installed audio programs, like Sony Acid Pro, Cinescore and Adobe Auition but not sure if they could cause it?
I've done the steps above and it hasn't worked. It seems to be the right speaker that is distorting but when i put headphones on there's no distortion
Jay
http://love4musicuk.webs.com
rich912
Contributor
If there is no distortion from the headphones then there is a fair chance that the problem is hardware related.
Unfortunately, in order to eliminate third party software as the cause, I have a feeling that support will ask you to do a further factory reset before accepting it for repair :slight_frown:
Love4MusicUK
Hardware related when it's only 4 month old?Not what i'd expect after paying 700 pound for a laptop. How do i go about getting it sent in for a repair?
Love4MusicUK
I forgot to mention that it's ok below a certain volume and also when the volume is turned down full i can still hear sound. I thought that maybe some settings for the audio are set too high?
rich912
Contributor
That is of course a possibility, but if it is one speaker that is distorting the only alteration I can think of is balance.
Go to Control Panel > Sounds and click on the playback tab. Click on Speaker/HP and then Properties > Levels.
Under Audio Output click Balance. If left and right are set at the same level then I doubt that this is the cause of the problem.
You could always experiment with external speakers, but as you mention that this problem is not evident using headphones I doubt that it will be with external speakers either.
Click support at the top of this page and select Get in Touch.
Love4MusicUK
The balance is set the same on both speakers. I don't understand how this could of happened as i've never dropped or banged my Laptop? Thank you, i will do that
Love4MusicUK
Hi, I contacted Support and they repaired it for me. Very quickly too, thanks Sony!
Jay
rich912
Contributor
That's good to hear Jay :slight_smile:
Thanks for letting us know.
