Lack of sound (temp) on RS-402
turbohat
This is odd. Every so often my RS-402 will go silent. Checking the advanced control panel for sounds, it is not muted, nor is the sound turned down. The only way to 'reactivate' the sound is to reboot.
Anyone else encountered this?
Cheers
1 REPLY 1
stevep-4
It is probably some program has take control of your sound card (such as Windows Media player, soem MP3 plaer etc.
do CTRL-ALT-DEL and see which applications and programs are running.
Close one program at a time and see if that helps.
