I have just purchased a FE21M - all good except every so often I lose internet connectively through the wireless network. The WLAN connection is stable at 54.0, and the situation is remedied by toggling the WLAN a couple of times to restart the connection. Does anyone have any ideas why I am losing the connection? (I don't think it's anything to do with my ISP because I have no such problems on another machine)
Thanks,
Feroze:smileyhappy:
Hi Feroze and welcome to ClubVaio.
Have you tried increasing the Performance of your WiFi card to Maximum?
Start>Right-click on My Computer>Properties>Device Manager
Expand Network Devices and double click on your wireless adapter, Under Power Options choose Maximum Performance,
That's how I fixed loss of WiFi on my FE21H however it wasn't under Power Options rather Power Management (pictured below).
Thanks for the replies. Advice followed and all AOK for the last 24 hours. Now, I want you all to keep those fingers crossed for me!
Regards,
Feroze
Have you windows XP? Have you tried installing Service Pack 2 it helps with wireless devices and makes it easier to connect. And it also offer greater stability.
Try a Belkin M Router,shit hot piece of kit.
Another possible remedy could be to change the channel your router and card uses to a lower frequency, sometimes this can also increase signal range too
