Installed usb dvd drive but now Pointing device wont work
john.richardson
I have just installed a usb to ide cable and connected an external dvd drive which works perfectly. Unfortunately, althogh a usb mouse works OK, my pointing device now will not i.e. moves a small distance then stops as if the computer is doing something else - sound like an irq problem but I don't know how to resolve it. Help please
4 REPLIES 4
john.richardson
Sorry - it is a Vaio K315S notebook
William
You could try using a mains powered hub, it could be a power issue.
john.richardson
Hi William - I forgot to mention in my previous post that the drive is already powered via a mains adapter so I can't see that being the issue - many thanks for taking the trouble to reply with your thought though
John
Thalamus.
Champion
Hi John,
Have you tried removing and re-installing your pointing device..:smileyhappy:
