Hello all!!
I am a newbie Vista-User and I accidentally disabled the recording device/michrophone from my VGN-CS21S/W and I cannot re-enable it. SHould I re-install audio drivers?
I need help!
I'm not sure if this will work but right click on the sound icon, select sounds theb playback. you should then see ur devices. right click to select enable on the device u need
My Realtek High Definition Audio (playback device) is properly working. I disabled the recording device (i.e. microphone)in the "recording" tab the message says; no audio devices are installed.
