Hey,
For some reason, my function keys and S-Buttons have stopped working!!? Any suggestions of how to fix this would be greatly appreciated!
Paul
Depends on your model Paul. Which is........?
yes sorry that might have helped... sorry.... tis a Vaio VGN-FS215Z
cheers.
Hi Paul,
Download the pre-installed utilities from Vaio-Link . Extract this file and then install the following in this order….
1 Sony Utilities (Installer folder 1)
2 Sony Shared Library (Installer folder 2)
3 Vaio Event Service (Installer folder 7)
You may possibly need to repeat this procedure a couple of times before the keys will work correctly.
hey, thanks. I will try your suggestion and get back to you and let you know whether I have any success. why would the buttons stop working? I don't understand!!?
cheers.
hey, i tried your suggestion but it said that i already had a newer version on my computer and it subsequently stopped the installation. any more suggestions would be welcomed!
