Help needed with screen resolution - driving me mad!
pstubbs50
I have a VGN AW11XU and all is great with it apart from the fact that any video (whether on DVD or online such as BBC iplayer) is very poor quality.
It looks the same as when you enlarge a low res image too much. It's pixellated and nowhere near as clear as it should be. There is also bad tonal gradation on the image.
I've updated the graphics driver using the Sony update.
I've set resolution at the highest (1920x1080) but nothing seems to make any difference.
Are there any other settings I can change? Is it something to do with Vista compatibility etc?
I would really appreciate any help/advice here as I am tearing my hair out with frustration - I just know that films should look stunning on this thing!
Thanks very much
0 REPLIES 0
