I have bought the new fancy Laser mouse VGP-BMS10 and have tried to connect it to my laptop Vaio VGN-FW160E, both of them are purchased in USA but I live in Sweden. Can you recommend me how to do.
I have tried to go through START - Control Panel - Bluetooth Devices - Add Wireless Divece - I have also started the mouse and pushed the connect but nothing works. Exvept this I have updated my Bluetooth drivers and now I would like your advice - what more can I do?
Benny
Hi Benny and welcome to the forum.
Just a thought but I assume that Bluetooth is enabled on your notebook?
You can enable/disable Bluetooth using Vaio Smart Network – either by double clicking the wireless function icon in the system tray, or Start > All Programs > Vaio Control Center > Network Connections > Vaio Smart Network > Advanced.
