Hi!
I have VAIO VGN-NS20J, I bought it yesterday and today after i turned my laptop on a small screen appeared saying "VCM Intelligent Analyzing Manager stopped working and was closed: A problem cause the application to stop working correctly. Windows will notify you if a solution is available."
what does that mean? and how can i slove the problem?
thanks in advance
Hi Upsy Daisy and welcome to Club Vaio.
Did this just happen once or does it happen every time you boot up? If it just happened once I would not worry. If it persists then give Vaio Link Support a call on Monday.
The file you mention is a Sony file and you will find it here: -
C:\Program Files\Sony\VCM Intelligent Analyzing Manager\VcmIAlzMgr.exe
I confess that I have no idea what it does. Have you installed all the software updates for your model from VAIO-UPDATE? There are quite a few updates for Sony software which may fix the problem.
