Autoplay doesn't work with memory stick
barmingmag
The autoplay used to bring up a menu of options (for example, the camera/scanner wizard to move pictures, etc) to take different types of media off the memory stick. This does not work anymore. I have been unable to find a solution to this. Any ideas?
6 REPLIES 6
robpaxton
Right click the memory stick icon in My Computer
Left click properties
Click the Autoplay tab
Setup the optons on the displayed page,
Regards, Rob
barmingmag
Thanks Rob, tried that and nothing wrong with options, tried changing, nothing, going back to default nothing. Any other ideas?
robpaxton
If you know when the problem started then perhaps windows restore might help.
Regards, Rob
barmingmag
Rob, I tried to restore as you suggested, some of the dates on the restore calendar did not work and those that did did not solve the problem of autoplay not working with the memory stick. Any further ideas apart from full recovery?
robpaxton
Sorry - I'm out of ideas. I don't think I would do a system recovery for this though. I would probably learn to live with it.
Hang on a while & see if anybody else has any ideas
Regards, Rob
robpaxton
