I have a number of Adobe (Acrobat, Flash player, Reader) and Java (Runtime Environment etc) programs installed on my laptop. There are 12 in all and I am trying to 'clean up' the laptop to gain a little extra space. I suspect that as these applications update they do not automatically delete their previous versions.
Am I allowed to list the 12 items here so that someone can advise which ones I can safely delete?
Thanks,
Gyron
Hi Rich912,
All sorted out thank you. After re-running Sucunia all I am left with is advice that Outlook Express needs some security updates - probably leave these since Symantecs 'Internet Security' has these in hand - I hope!
Thanks once again for excellent advice and help,
Kind regards,
Gyron
You're very welcome Gyron.
