TV - UK Bravia will it operate when I move to Shanghai?
herojay
hello Forum,
I purchased my Bravia in UK and know the electricity / frequency is the same (need plug adaptor) and also both countries TV systems are PAL.
Will my Sony Bravia KD - 49X8505B 4K 3D TV operate correctly in Shanghai, China so I can watch Shanghai TV?
thanks
jay
1 REPLY 1
Anonymous
Not applicable
Hi there
Unless another forum member can confirm, I think it might be best if you contact Sony Support to find out the answer.
Upon saying that, i found this thread:
http://www.shanghaiexpat.com/phpbbforum/electrical-appliances-uk-to-china-t134122.html
A little bit of advice though - factor in what it would cost to transport the tv to china, and then what it would be to sell the TV in the UK and purchase a new one when you are there.  Also, TVs are fragile things, so it would need to be packed properly and still then you risk damage during transport.
Cheers
