Sony XF70 Info bar
Nuke144
Sony XF70 Info bar
Evening all.
Having trouble with thr info bar popping up on a bravia xf70. Especially while playing games kn my ps4. Its an excessive nuisance every time a trophy pops etc.....
Had a look on the forum already and couldnt see anything for this model, is there anyway to stop this happening?
1 ACCEPTED SOLUTION
Win_88
Specialist
Hi Nuke,
I don't think it's possible to completely disable the info banner on the XF70 series. The banner will appear whenever the TV detects any change in the signal. You can still dismiss it using the info button on the remote though.
Win_88
5 REPLIES 5
Pascale_F
Moderator
Hi Nuke144,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Nuke,
Win_88
Nuke144
Thanks Win_88.
It seems a silly feature, especially with the ps4 seemingly causing multiple changes during use. Do all TVs do this? I found on these foruns that on other Sonys you can turn it of, so wondered if i was just being stupid, obviously not.
Cheers again.
Win_88
Specialist
Hi Nuke,
I don't think you're doing any thing wrong here. I'll try to get this feedback to my Sony contact. Maybe it will be changed in the future or something.
Cheers,
Win_88
Nuke144
Thanks Win_88
In the end I didn't give it too long.  Just went and exchanged the TV.  Way too distracting, and inconvenient, despite some of the good aspects of the TV.
Gave the Sony customer services my feedback too, after they replied to my email. Some things just arent meant to be it seems.
