Remote Control Default settings
avshore
I don't know how I have done this but I was fiddling with the sync menu and managed to lock out my digital TV, it now says no signal.  I had all the digital channels before but now I have them all apart from BBC1 and BBC2. I don't know if I need to reset to default the remote, the TV or my brain. I cant find enough information on iManual.I was in the sync menu because when viewing 3d I had split screens and I could not select the Options button from the remote to get to the menu to change this, i had to go in via the sync menu.  I have managed to get the options button to now work directly from the remote when viewing 3d  but cannot get my digital channels back. I spent most of last night trying to resovle this. Any comments would be appreciated. NX713 46"
Tags (1)
1 REPLY 1
Thalamus.
Champion
Hi avshore,
welcome to Questions & Answers..:smileyhappy:
As no one seems to have offered a solution I would say try resetting your Bravia and follow the set up again..
If you still experience problems with the remote then try removing the batteries for 30 mins then replace and try again..
