hx855 or hx853 does not work with OSX Mountain Lion ?
profile.country.sv_SE.title
stekfett
It doesn't seem like the hx855 work with Mac OSX Mountain Lion (on my Imac late 2011). There is flashes every fourteen seconds as you can se if you use the link below. The erlier OSX Snow Leopard works very well thoug.
http://www.youtube.com/watch?v=t68eFP86ym8
Is there anyone that have tryed the combination abowe?
Do you think that Sony going to fix this with an software update soon?
Message was edited by: stekfett
1 ACCEPTED SOLUTION
Catmambo
Contributor
Hi
If it worked with Snow Leopard but not with Mountain Lion, maybe Apple will fix something? Sounds like there is an issue with the graphics drivers they have deployed, as first new builds of OSX are apparently notoriously hit and miss, it will likely be fixed from their side as patches are released.
1 REPLY 1
Catmambo
Contributor
Hi
