Sony KDL-S32A12U (manufactured Feb 2006).
I bought my very hard of hearing father some wireless headphones for his TV (details above). However I am struggling to connect them as I cannot find the screen to adjust the audio output. I am assured by the company I bought them from that the headphones are suitable for “most TVs” and that I need to alter the audio output. I have tried all of the buttons on the remote which incidentally does not have a Home button (is the Menu button the same thing?). Also TV audio output has to be set to PCM?? Any advice anybody can offer would be most appreciated. Thank you.
Hello @Puxtongirl,
which headphones are you trying to use and how are they connected?
I recommend to use Sonys SRS-LSR100 or the SRS-WS1.
- Nic
