Help connecting Wii to Bravia TV
dagamso
Need to connect Wii to Sony Bravia KDL-40HX723. Alreday have connectedSony  3D sytem and Sony Home Cinema system, with Sky Box. All plugs seem to be in use.
1 ACCEPTED SOLUTION
Bravia55HX
you have a scart input on the rear of the set so with the Wii lead and scart adaptor that comes with it you can connect the Wii to the tv in this manner.
1 REPLY 1
Bravia55HX
