Flashing lights
goonernos
Flashing lights
Standby light flashing 4 times on my KDL-40S2010 Anything i can do or is it terminal??
1 ACCEPTED SOLUTION
Thalamus.
Champion
Hi goonernos,
welcome to Questions & Answers..
If  the stanby light is flashing red then this indicates that the TV's self diagnosis mode has been activated, I suggest you contact your local authorised Sony  service centre and inform the them of the sequence that the Standby  light flashes. Use the following link to find your nearest: Authorised  Sony service centre
2 REPLIES 2
Thalamus.
Champion
Hi goonernos,
Raggyman
Wow, I am just experiencing the exact same problem as you... and same model number.
I suspect in my case it is the backlight inverter.  Is yours poorly lit on the top left hand side of the screen?
I really am starting to think that this is a major design fault with these Sets.
