I can't get BBC i player to work thru bravia internet video, despite downloading latest firmware from sony website
Hi Clutcher - as mentioned, do try updating the firmware manually first and then refresh the content.
Good job @Richliv - glad its working now
I have just purchased a KDL-32EX713 and am having the same problem accessing iPlayer.
All other internet services working fine. I have refreshed network content and tried everything else mentioned on this forum.
I have downloaded the new firmware but the tv won't recognise the USB I am using.
I am on a Mac - does this make a difference?
Do I need to use the Sony wireless dongle USB - the Mac does not recognise it?
Or will the Tv update itself thru the wifi?
Thanks for any help
I would try using a wired connection before trying the wifi, although if everything else works, it seems unlikely to be the problem. As I say, all I did was reconfirm the Wired Settings option and my inlayer started working. Before that other net services had been working fine so somehow this is specific to iplayer with the Bravia software.; Interestingly (to me) I had to send my set back to Amazon and when a replacement with a properly working screen arrived , iplayer worked first time. I wonder therefore if the Sony iplayer firmware has to register itself with Sony or the BBC before it will work at all.
It won't work unless you update to the latest firmware. Not aware of any issues with using a Mac. Bear in mind you have to leave the update file in the directory when you copy it over, not extract it and put it in the root.
The update will not be performed if the folder structure, name of the folder, or name of the file inside the folder is modified.
same happening on KDL-40NX713 which I have only bought because it has wireless built in and wired is not an option Iy has the latest firmwar, well at least according to sony.
Anyone any ideas
Any ideas why the TV won't recognise the USB? It's in working order. I just unzipped the download the copied whole folder to USB...no renaming or modifying...
What version of the firmware are you running? Can you explain what happens when you press the iPlayer logo.
The firmware is 0107 - I think 08 is the latest??
When I press iPlayer it gives me the loading message then says it needs to be updated - go to Product Support and check Automatic System Update is on - which it is...
Yes automatic update can be very slow and unreliable - it rely's on downloads being delivered over the air(waves) -OTA. So its much quicker to simply download the update onto USB stick and update it manually. If you check the top of this page and press support>online support and then choose your TV from the drop down menu and follow the instructions, you should be able to update pretty quickly
