Activate enhanced features on kdl40ex503
vinhill22
Hi, I have connection to the Internet ok but it says to activate enhanced features register then enter code which is on my tv screen. I am already registered  but cannot seem to find any place on the sony site  to enter the code the TV is saying to enter. Thanks
2 REPLIES 2
Catmambo
Contributor
Honestly, don't worry about this menu option - I think its removed with the later firmware updates as it doesn't really deliver anything valuable..
vinhill22
ok eduzzel thank you for that, appreciate your answer and the speed of the reply.
kind regards
