Xperia Pro-I Android 12 One-handed mode is ruined
profile.country.PT.title
Quasar
I liked the One-handed mode in Android 11, because we could access to the entire screen with the thumb finger, since the main future of the app was to zoom out the all screen of the mobile to ease access.
Now, in Android 12, the app is screwed, since I can't adjust the dimension of the screen, I can't use only one thumb because the width is the same as the original screen, I can’t change to use the right or the left thumb, and I don't see the entire screen.
Why Sony, why ???
How could you ruined a good app ?? Can I have the Android 11 App in the Android 12 ???
4 REPLIES 4
profile.country.PH.title
MarlonUk1
unfortunately there is no official way to downgrade android versions..
this might be also a google android implementation.
Quasar
Well, I just would like to use the other version of the app, not to downgrade to Android 11.
Quasar
But enjoying the Android 12 in the Pro-I.
The Use of the battery also seams to be broken.
It doesn't keep the time the smartphone is on from the last charge.
SkyNet404
Specialist
Hey @QUASAR,
Yea that sucks, but it might be rectified again with another update, as it's not an actual issue with it.
It's just how it looks right now, but yea that's a bit inconvenient.
Hope it gets noticed
