Mine was a 2g network initially, after i've got my XP i converted to 3g HSPA(!dea-INDIA) network, since i'm not satisfied with the battery life, i'm planning to revert back to my old 2g network, does it improve anything or remains same ????
In your mobile you could go to settings > more/wireless and networks > mobile networks > network mode > select GSM mode only...
it may help
