Switch between 2g and 3g
jithesh_7
can someone tell me how to switch between 2g and 3g
1 ACCEPTED SOLUTION
Uliwooly
or you can use this widget it's quite nice
Power Control
https://play.google.com/store/apps/details?id=at.abraxas.powerwidget.free&feature=more_from_develope....
6 REPLIES 6
Uliwooly
when you say 3G are you referring to the data plan?
jithesh_7
Yes....the 3G data plan
Uliwooly
there are myriad options
settings -> wireless & networks -> mobile networks > uncheck enable data
or use a widget
on the homescree -> menu > widget > data
Uliwooly
Power Control
jithesh_7
thanks a lot for the quick and effective reply!!
Uliwooly
Anytime Slightly_smiling_Face
