Stopped in between update and not starting after that.
yourtushki
Hi
I was recently updating my phone (Xperia P) from PC Companion 2.1. When it asked me to restart the phone after downloading update from server, i was not able to start it again. Afterthat phone is not working at all. When ever i start the phone it shows below icon. Power + up key is not working too.
What can i do to reset it now?
1 ACCEPTED SOLUTION
profile.country.PH.title
MarlonUk1
4 REPLIES 4
MarlonUk1
ryan515
Contributor
Repair it using SUS.
or try manual upgrade:
http://talk.sonymobile.com/message/220505
yourtushki
Thanks man. I updated with it and all fine. Appreciate your prompt reply.
yourtushki
Hi Rayn. Thank you for reply. I tried nolramlb's solution and it worked.
