Hello, after I've upgraded to ICS yesterday Skype stopped to work. Everything looks like OK: I can start Skype -> Login -> from Skype pov I'm online but nobody else see me as connected to Skype network.
I've tryied connect through 3G and WiFi - the same result. No actual connection. On previous version of android everything with Skype worked well.
Any ideas or the same behaviour?
Thank you.
No problem counts for all devices
Mostly happens when the phone was idling for 6 hours with wifi on I just turn wifi on and off and fixed so don't worry about me anyway
I'm by the way still running gingerbread
you should update to ICS it's AWESOME!!!
if you don't want to wait
How to manually update 2012 Xperias to android 4.0.4 6.1.A.0.452
http://talk.sonymobile.com/thread/41609
Well i'm going to wait for the official release in Belguim. ^^
So I rather like to wait
Anyway it's a great device the only sad thing was that it did not had ICS
Indeed, check the thread you could backup your current firmware and flash ICS then once it's available in your country flashback
Had this problem, and was fixed by un-installing and re-installing Skype.
I am face same problem. start skype then sign in and it automatically sign out. also demo video running on phone every time even its lock and charging.
any body can help me?????????/
Some list what you could perform:
i own an Xperia S and before ICS update skype was wokring fairly well with an occasional crash or login issue....after ICS update it is completeley gone...and everytime gives the same error
Skype has stopped working.....would you like to sign in again or exit Skype ?
i have a very heavy use of skype and have tried installing it again and again older versioons as well as repairing rebooting but doesn't help. Its useless now
please help... if their is any new version or update coming for skype fix or any other option
