Hi, I upgraded to 4.0.4 ICS, but I found a performance degradation of the terminal. Both the content navigation, both in applications / games. Even the heavy lag in Temple Run. I also restored the factory settings and formatted the sd. Do you have any solution? Thank you
if you want to downgrade to 2.3.4 you have 2 options
1) take your phone to a sony repair center
or
2) manually downgrade your phone either by wotanserver or flashtool
there are few things you can do
1st use a different launcher
2nd use dialer one
3rd settings > apps > all tap on apps that you don't use and disable them
4th regarding games there isn't anything you can do about it
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
well games and apps won't run as smooth as they did in Gingerbread.. well if you want a bit of improvement in performance then run a repair software via PCC or SEUS or other option is downgrade to Gingerbread
Anytime
