1) how to play video in full screen ?? how to change aspect ratio ?? or recommend any player to play video in full screen??
2)some times Xperia go restarts automaticallly while listening to music?? why this happens??
3)some apps like plants v. zombies are not working?? why ?
4)before buying this phone i used SE yendo in that i have a habit of switching off phone in night..can i do it in xperia GO??
answering all questions is not necessary..reply with what you guys know... DO IT FAST...
1.) just tilt your phone to landscape orientation
3.)try reinstalling it
4.) turning an android phone off is like turning your computer off, besically it's dead,
so for example. you set an alarm in the morning but you turn off your phone that night, the alarm would not go on.
1.)
2.)try to reboot to free up more ram
3.) do you encounter an error? what does happen when you start it? try reinstalling it.
4.) yes you can turn it off, but be warned alarms do not work when phone is turned off
THANKS FOR reply Nolramlb
3)does not loading ...! and showing error
4)i cant get you...can you tell me clearly??
Thank you so much ..
no problem
