phone storage to Micro SD
Not applicable
why the application downloaded is installed directly to phone storage?? we don't have option to choose install to micro SD?? how to?? it makes me cannot install many apps in my phone
1 ACCEPTED SOLUTION
Uliwooly
no you can't, that's only for Android 2.2 and above
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
4 REPLIES 4
Uliwooly
Uliwooly
if you want 2.2 or 2.3 here are the alternatives
http://forum.xda-developers.com/showthread.php?t=1379754
http://forum.xda-developers.com/showthread.php?t=914513
2.3.7 Custom ROM for Xperia X8/W8
http://code.google.com/p/minicm/downloads/detail?name=MiniCM7-2.2.1-shakira.zip&can=2&q=
Uliwooly
if you want apps2sd you can use this
if you want apps2sd feature on your phone do this
http://forum.xda-developers.com/showthread.php?t=800555
or you can use Link2SD BUT you need to root
https://play.google.com/store/apps/details?id=com.buak.Link2SD&feature=nav_result#?t=W251bGwsMSwxLDM...
Uliwooly
to root you can use superoneclick
http://forum.xda-developers.com/showthread.php?t=803682
