Hi All
I Was updating my Xperia U, Suddenly internet has gone and from there on no display in my mobile
Pls help me on this!!!
I would suggest performing a repair of software with the Update Service as this seems to be a bad install. I have supplied a link below that will allow you to download the Update Service.
repeat the entire step with SUS.
Thanks for the suggestion.. now its working fine... sorry for delayed update
No problem, I hope all goes will for the furute :smileygrin:..
Hi all,
I have update my Xperia U yesterday with lastest firmware.
This morning it drain and I can't event turn it on.
Could you please kindly help me with this?
Thank you!
recharge using wall charger supplied by Sony for 2 hrs and then turn it ON after disconnecting it from wall charger.
