No 3g connection android v 2.3.4 model sk17a
diegolopez83
Movistar Colombia, just update from 2.3.3 to 2.3.4 and now 3G doesnt work. any ideas? thx  a lot
base band  -203028D-64
1 ACCEPTED SOLUTION
Uliwooly
this is an example
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:[email protected]
Password:CINGULAR1
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410
APN Type: leave blank
MENU -> Save
google your APN settings: apn settings android __name of your network__
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
3 REPLIES 3
Uliwooly
check the APN settings (enter them manually) and if your SIM card it's older than 1 year get a new SIM card
Uliwooly
this is an example
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Password:CINGULAR1
Server: leave blank
MMS Port: 80
MCC:310
MNC:410
MENU -> Save
Uliwooly
if you don't want to wait for movistar to approve and release ICS then
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.587 & others
http://talk.sonymobile.com/thread/38251
