How to create a folder in XP running ICS
Sagar
Hi
It seems that I am not able to create a folder on home screen on my XP running ICS. Can anyone tell me how to do that?
Sagar
1 ACCEPTED SOLUTION
Miltos95
Contributor
Can you drag and drop an app on top of another app? That should do the work i guess!
3 REPLIES 3
Miltos95
Contributor
Sagar
Thanks Miltos.. That did the trick. Slightly_smiling_Face
Miltos95
Contributor
Glad it works on ICS too! :smileygrin:
