отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
How do I set my music as ringtone
canton751
Посетитель
I want to set my own music as ringtone or notification sound , but how do I do that ?
with the walkman app does not work
this is translated with google translate
please help me
13 ОТВЕТ 13
RVCH1345
Посетитель
thank you so much "Amey Enthusiast" for Well guided
Nitin150401706
Посетитель
Sir I am trying to use my music ringtone but this mobile is not giving any option
SantosEvelyn
Посетитель
The first thing is you need to download the ringtone, then go to the settings section of the phone and select your favorite ringtone and set as ringtone.You may consider baixar toque do iphone  that I just found.
SS1977
Посетитель
Please save your desired music in ringtone folder at internal storage. Then you will be able to see that music in ringtone list. SETTINGS->SOUNDS->PHONE RINGTONE
