Yesterday a friend sent me a picture over nfc with his XPERIA S. I recived it with no problems. How is this possible if i dont have nfc? There is no nfc settings, no button nothing...?
And can I send the same way, is there a update to have a nfc settings or something similiar...
you don't have an NFC sensor, double check how he sent it, it was probably through mms or an app like hoccer
unrelated topic, if you have some time please check this thread
ok so it could be sent another way, maybe it was sent over bluetooth ....
thanks for a fast answer
no problem, btw check Hoccer, it's quite useful and fun to play with
