Is there a way that i can stop the camera button from launching the camera if press long while on lock screen? it keeps launching the camera apps while in my pocket..i guess it's because of that features. Thanks!
the servers are probably still busy
s1boot download? what is this? it has an x color red. and it says device unplugged...device not successfuly installed...
that mean that you need the drivers
when you run it turn off your firewall and antivirus
im trying to update also my friends xperia mini and it's SI is in the list. but it always says you have the latest software.
servers are overloaded just wait a bit longer
