Baseband Issue st15i .69
JulianoFB
I've flashed -66 baseband on my Android 2.3.4 (.69), guessing what gain some enhancements, but I notice signal issues.
-64 baseband have the same issue, and in *-47, all was working good. The problem is: I don't have and don't find the *-47 baseband to flash again. Can someone give me a help to download the *-47 baseband in ftf format or something? I know is old, but I don't want an updated with issues, btw I'm only requesting for help =].
Thanks!
* 8x55a-aaabqoazm-20302204-47
ps: sry about the english.
1 ACCEPTED SOLUTION
Nabeel
Master
Hi, download the firmware of of your choice for ray here and just flash the baseband, i hope you know how to flash just baseband using flashtool
14 REPLIES 14
Nabeel
Master
JulianoFB
Only baseband from Ray firmware is correct? I mean, the baseband is compatible?
I know how to flash, just to checking:
     When I choose an firmware to flash, in "exclude:" I check everything except baseband, right?
Thanks.
Nabeel
Master
Yess only for ray firmware ( any baseband but only of ray )
No nopes, Here is how its flashtool version 0.7.1
All the best Slightly_smiling_Face
JulianoFB
Thank you so much!
All links to download Generic Nordic ST18i (Ray) don't work. A lil help again?
Nabeel
Master
Isn't that quite old but
Okh tellme why you want to change your baseband ?
JulianoFB
To go back because, I update my baseband just to test. I tried .64 and .66 after. But the battery comsumption in both and the signal quality is not good like my stock baseband. Now I wanna a baseband -47 or close (my stock baseband =] ), because i don't have it anymore.
Nabeel
Master
Okh,
Do tell me once you complete it Slightly_smiling_Face Winking_Face
JulianoFB
Dude just one more thing, is seems hard to find Ray generic, no by wotanserver, but I don't want use it. So I've found .562. what is the baseband on .562?
Ah... And a big... big thanks! xD
Nabeel
Master
-56
Happy to help buddy Winking_Face
EDIT : SORRY SORRY wait a minute not -56, back in a minute
EDIT 2 its -70
