Arc S ICS upgrade problem
Not applicable
I'm having a problem trying to update, I get as far as holding back and attaching the USB, windows says new hardware found, but can't find drivers, then nothing else happens.
I've updated both PC Companion and SEUS, no change.
I've turned of anti-virus and firewall, no difference.
Getting a bit fed up now, please help!
1 ACCEPTED SOLUTION
Uliwooly
turn off your firewall and/or antivrus, reinstall SUS and restart your PC then turn off your antivirus and/or firewall and try again
5 REPLIES 5
Uliwooly
Not applicable
Worked a treat, thankyou
Uliwooly
anytime, quick suggestion, do NOT install any taskiller, antivirus and/or battery app at all
Not applicable
Why? I've been using lookout, can't say i've noticed any problems, you think i should remove it?
Uliwooly
those apps are bad news, they create issues with other apps, also check the permisions (on your comptuer go to play.google.com > sign in > my apps > click on them and click on permisions)
