again pcc problem
Not applicable
again pcc problem
l can't update my mini...pcc and seus again don't work,why?
1 ACCEPTED SOLUTION
Uliwooly
you don't have to post all over the forum, one time is more than enough
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
3 REPLIES 3
Uliwooly
Not applicable
ok,tnx for the info...l am new here 🙂
Uliwooly
did SUS worked? if it didn't, restart your PC -> turn off your firewall, antivirus and then run it again
