HELLO WORLD
MY question is to know how the next updates will be made if i manually flash the 4.0.4 ICS in my Ray, will I still be normally notified for updates or will i have to undergo different processes???
it will be the same but if you are locked to a network the network/carrier's icons will be gone
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
http://talk.sonymobile.com/thread/38251
Thank you Super USer:smileywink:
Anytime
