- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I've got m4 dual sim version. When I'm using viber with my mobile Internet, not with wi fi, it doesn't work! All the other apps do! I've checked the settings, app permissions.... Nothing helped
Topic edited by Rickard
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If it works over WiFi but not mobile data while other apps works on mobile data, it sounds like it's being blocked in the network by your operator.
What you can try is to remove the proxy from your internet settings and see if that helps under Settings -> Mobile -> Mobile networks -> Access Point Names. If this doesn't help, i recommend that you contact your operator for assistance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you on 3G or 4G? if not perhaps the data its too slow, also check if your carrier/network has blocked this service.
Do you have any antivirus or taskillers? stamina mode? battery apps? disabled background data on any app?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm glad to hear that you got it solved
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I used Viber,
I would recommend Whats App instead,
It seems to work a lot better for me , works on data, and uses much less data than Viber!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
try to connect through an vpn
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
how are you BLE TO USE IT PLEASE ELABORte i hVE THE SAME PROBLEM WITH 4G THE VIBER DOESNT WORK BUT ON WIFI IT DOES
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
