Mobile Lock problem
prasanthmku
Mobile Lock problem
am unable to lock other than Pattern, Pin, and password. Other lock shows like disabled by administrator?  Please help me to get those Slightly_frowning_Face
1 ACCEPTED SOLUTION
Rickard
Master
Some security softwares and company policies can disable these options. Go to Setting -> Security -> Device administrators to see what administrators you have in the phone. If you disable the administrator you'll be able to select for example Swipe but the software/account that added the administrator will probably stop working.
2 REPLIES 2
Rickard
Master
prasanthmku
Issue resolved by clearing credentials in setting-> security
