xperia L sound issues
tabish13
Album Not Displaying, Now no sound for calls and music also can anyone help out not even one month completed for purchase
please help me out
1 ACCEPTED SOLUTION
Uliwooly
I can't answer that question, you have to contact Sony if its a hardware issue, but before you even start considering that, try my suggestions
23 REPLIES 23
Uliwooly
can you play music through the loud speaker?
Uliwooly
tabish13
no sound man through loud speaker.
Uliwooly
test your phone with the suggestions above and/or repair your phone if the problem continue then its a hardware issue, you will have to take it back to the store or a sony repair center
tabish13
As its less than a month,will sony give me a replacement if there is any hardware issue ?...
Uliwooly
tabish13
yes m trying that... thanks Slightly_smiling_Face
Dip_xperia
There might be a loose connection issu. I also had that. I just covered my phone with soft jelly pouch and hitted the speaker area softly with wooden door. That problem solved!!!
Tags (1)
