when i open camera from lock screen it take picture immediately but in my friends xperia l its open and wait until the camera sutter has been press. proximity sencer hangs when headphone is attached
Could you please elaborate the behavior you are experiencing with the proximity sensor?
Proximity sensor get start itself when i receive any call while my headphones are plug in and switch off the sensor i need to turn off my device and switch it on again..
Hi at007,
This is already a bug that is already posted.( http://talk.sonymobile.com/t5/Xperia-L/proximity-sensor-issue/m-p/519769#M8441)
But i could suggest you a temporary alternative to make the sensor turn off without having to restart the phone.
just call any contact and end it immediately, doing this will turn off the sensor.
For the actual bug, we still waiting like you.
A small suggestion, please search through posts before posting which will save your time
thank you for the solution ..
